[mapguide-trac] #601: MapGuide Maestro: image tiling in composite mode is not working
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jun 17 03:55:07 EDT 2008
 Reporter:  dumas65  |         Owner:  ksgeograf
     Type:  defect   |        Status:  new
 Priority:  low      |     Milestone:
Component:  Maestro  |       Version:
 Severity:  trivial  |    Resolution:
 Keywords:           |   External_id:
Comment (by dumas65):
 I installed Ecw libraries according that link. It didn't help. MapGuide
 maestro still can not project files.
 Rechecked again. It is not only ecw case. I tried with esri tiff (tiff and
 external world file) and simple geotiff. All files were not projected
 correctly, same result like in attached files.
 If I add resource form alias (e.g tiffs with external world files), data
 is displayed correctly in the map. Pushing 'set view to current layers
 extent' in map properties returns correct coordinates. Even in data source
 properties 'coordinate system override' displays correctly - "Transverse
 Mercator units...
 If A add '''same data''' using composite option in 'coordinate system
 override' I have default. In map properties 'set view to current layers
 extent' I have -10000000,-10000000,10000000,1000000.
 Again, this happens with ecw, tiff and geotiff file formats.
 Any more ideas?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/601#comment:9>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
