[mapguide-trac] #601: MapGuide Maestro: image tiling in composite mode is not working
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jun 17 05:19:33 EDT 2008
 Reporter:  dumas65  |         Owner:  ksgeograf
     Type:  defect   |        Status:  new
 Priority:  low      |     Milestone:
Component:  Maestro  |       Version:
 Severity:  trivial  |    Resolution:
 Keywords:           |   External_id:
Comment (by ksgeograf):
 Are you saying that it works when you use an alias, but not when using
 direct path?
 If so, does the path have spaces in it?
 I think there was some reports of trouble with spaces in the path for
 GDal.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/601#comment:10>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
