[mapguide-trac] #601: MapGuide Maestro: image tiling in composite mode is not working
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jun 26 08:27:51 EDT 2008
 Reporter:  dumas65  |         Owner:  ksgeograf
     Type:  defect   |        Status:  assigned
 Priority:  low      |     Milestone:
Component:  Maestro  |       Version:
 Severity:  trivial  |    Resolution:
 Keywords:           |   External_id:
Comment (by dumas65):
 So, after Upgrading to 1.0.8 coordinates are detected OK. I did same
 things like before and same you wrote to here. That's fantastic.
 Unfortunately MGOS can not display more than one image: 1. If data source
 is created using 'single file or folder'. All cordinates OK (spatial
 contex) Layer is displayed in the map correctly.
 2 If datasource is created using composite mode (sigle file, alias or
 folder -it does not matter). Coordinates are detected, (spatial context
 and config file.) But in map images are not displayed. I tested data with
 'set view to current layers extent' coordinates are detected, however
 layer is not displayd in the map.
 Attaching config files.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/601#comment:18>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
