[mapguide-trac] #601: MapGuide Maestro: image tiling in composite mode is not working
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jun 26 16:25:34 EDT 2008
 Reporter:  dumas65  |         Owner:  ksgeograf
     Type:  defect   |        Status:  assigned
 Priority:  low      |     Milestone:
Component:  Maestro  |       Version:
 Severity:  trivial  |    Resolution:
 Keywords:           |   External_id:
Comment (by dumas65):
 A'm Sorry. I was working on same feature datasourse, and just changing
 properties of  composite (to same some time on creating layers and adding
 it to map).
 Now I tried with new datasourse. It seems that i can see images added in
 composite mode. At least when I add 1 image. If I add more than one image.
 There is problem in cordinate detection and images are resized.  I will
 add config files tommorow.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/601#comment:19>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
