[mapguide-trac] #601: MapGuide Maestro: image tiling in composite mode is not working
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jun 30 10:50:30 EDT 2008
 Reporter:  dumas65  |         Owner:  ksgeograf
     Type:  defect   |        Status:  assigned
 Priority:  low      |     Milestone:
Component:  Maestro  |       Version:
 Severity:  trivial  |    Resolution:
 Keywords:           |   External_id:
Comment (by dumas65):
 I made little research on composite mode and image tiling. Look what I
 found on my system:
 1.Adding one ecw file works perfect. Everething detected fine, displayed
 correctly.
 2. Adding more then one image does not work. Some min/max points are wrong
 detected (config and ecw files will be attached for checking). Map view
 only image 2764.ecw is displayed and its takes all view extend.
 3. Same using alias. some coordinates are misdetected, but image in map is
 not shown.
 Can you check you have same?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/601#comment:20>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
