[mapguide-trac] #454: MapGuide 2.0 - login.php Administrator Fails
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jun 26 15:42:12 EDT 2008
 Reporter:  crispinatime  |         Owner:  ronnielouie
     Type:  defect        |        Status:  new
 Priority:  high          |     Milestone:  2.1
Component:  Map Admin     |       Version:  2.0.0
 Severity:  major         |    Resolution:
 Keywords:                |   External_id:
Comment (by jbirch):
 Can you confirm in phpinfo() that the path to the runtime php.ini is set
 to the correct value?  I wonder if there's a stray php.ini getting in the
 way, or if the following registry key isn't set correctly (or maybe has
 the wrong permissions):
 HKEY_LOCAL_MACHINE\SOFTWARE\PHP\5.2.5\IniFilePath
 It should be set to something like:
 C:\Program Files\MapGuideOpenSource2.0\WebServerExtensions\Php
 Jason
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/454#comment:17>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
