[mapguide-trac] #454: MapGuide 2.0 - login.php Administrator Fails
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jun 26 15:46:46 EDT 2008
 Reporter:  crispinatime  |         Owner:  ronnielouie
     Type:  defect        |        Status:  new
 Priority:  high          |     Milestone:  2.1
Component:  Map Admin     |       Version:  2.0.0
 Severity:  major         |    Resolution:
 Keywords:                |   External_id:
Comment (by jbirch):
 Also, check to make sure that the PHPRC environmental variable isn't set
 to an alternate location; this value was checked AFTER the registry
 setting prior to PHP 5.2, so would not have been noticed in an earlier
 version.
 http://www.php.net/manual/en/configuration.php
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/454#comment:18>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
