[mapguide-trac] #454: MapGuide 2.0 - login.php Administrator Fails
Rock Beans rockbeans at gmail.com
Thu Jun 26 16:09:38 EDT 2008
Thanks!
Added String to this location which contained the PHP.INI file:
HKEY_LOCAL_MACHINE\SOFTWARE\PHP\IniFilePath
Everything works now as far as PHP seeing the MapGuideApi using PHPInfo();
which is a start. Maybe the current mapguide installer is not doing this?
Not sure why this happens but I have seen it a lot. Only now do I know why.
Thanks again!
The Rock
On Thu, Jun 26, 2008 at 2:46 PM, MapGuide Open Source <
>  Reporter:  crispinatime  |         Owner:  ronnielouie
>     Type:  defect        |        Status:  new
>  Priority:  high          |     Milestone:  2.1
> Component:  Map Admin     |       Version:  2.0.0
>  Severity:  major         |    Resolution:
>  Keywords:                |   External_id:
> Comment (by jbirch):
>  Also, check to make sure that the PHPRC environmental variable isn't set
>  to an alternate location; this value was checked AFTER the registry
>  setting prior to PHP 5.2, so would not have been noticed in an earlier
>  version.
>  http://www.php.net/manual/en/configuration.php
> Ticket URL: <https://trac.osgeo.org/mapguide/ticket/454#comment:18>
> MapGuide Open Source <http://mapguide.osgeo.org/>
> MapGuide Open Source Internals
> mapguide-trac mailing list
> mapguide-trac at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-trac
URL: http://lists.osgeo.org/pipermail/mapguide-trac/attachments/20080626/f949a9ee/attachment.html
More information about the mapguide-trac mailing list
