[mapguide-trac] #454: MapGuide 2.0 - login.php Administrator Fails
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jun 26 16:12:25 EDT 2008
 Reporter:  crispinatime  |         Owner:  ronnielouie
     Type:  defect        |        Status:  new
 Priority:  high          |     Milestone:  2.1
Component:  Map Admin     |       Version:  2.0.0
 Severity:  major         |    Resolution:
 Keywords:                |   External_id:
Comment (by cgountanis):
 Added registry entry type "String" to this location which contained the
 PHP.INI file:
 HKEY_LOCAL_MACHINE\SOFTWARE\PHP\IniFilePath
 I also tweaked the windows path and made sure webext\php was first as
 well, maybe helped?
 Everything works now as far as PHP seeing the MapGuideApi using PHPInfo();
 which is a start. Maybe the current mapguide installer is not doing this?
 Not sure why this happens but I have seen it a lot. Only now do I know
 why. Thanks again Jason Birch!
 Still consider this a bug in the installer or something.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/454#comment:19>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
