[mapguide-trac] #454: MapGuide 2.0 - login.php Administrator Fails
MapGuide Open Source trac_mapguide at osgeo.org
Mon Mar 10 09:36:12 EDT 2008
 Reporter:  crispinatime  |         Owner:  ronnielouie
     Type:  defect        |        Status:  new
 Priority:  medium        |     Milestone:  2.1
Component:  Map Admin     |       Version:  2.0.0
 Severity:  major         |    Resolution:
 Keywords:                |   External_id:
Comment (by crispinatime):
 ... that's defined the problem!
 Fatal error: Call to undefined function MgInitializeWebTier() in
 C:\Program
 Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapadmin\login.php on
 line 70
 I googled a bit and found some vague references to the same issue and
 MapGuide.  Perhaps you have no issues in dev because you all have a full
 PHP instaltion and configuration.  I only install with IIS and the .net
 client (and PHP admin of course).  If it helps I am sure this was from the
 ticket taking PHP to 5.2.5 after RC2.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/454#comment:12>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
