[mapguide-trac] #518: Zoom Rectangle calculation assumes lower-left
to upper-right dragging in AJAX Viewer
trac_mapguide at osgeo.org
Tue Mar 25 15:36:08 EDT 2008
#518: Zoom Rectangle calculation assumes lower-left to upper-right dragging in
AJAX Viewer
Reporter: nclayton | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: AJAX Viewer | Version: 2.0.0
Severity: minor | Keywords: Zoom Rectangle
External_id: |
In ajaxmappage.templ, the code assumes that users will always go lower-
left to upper-right when drawing the Zoom Rectangle box.
pt1 = ScreenToMapUnits(x1, y1);
pt2 = ScreenToMapUnits(x2, y2);
mcsW = pt2.X - pt1.X;
mcsH = pt2.Y - pt1.Y;
If a user (like myself) drags from upper-right to lower-left, mcsW and/or
mcsH will be a negative value which will throw off the zoom operation.
By checking for a negative value then multiplying by -1 after the
assignment will give accurate width and height values for the drawn box:
if(mcsW < 0){ mcsW = mcsW * -1; }
if(mcsH < 0){ mcsH = mcsH * -1; }
Once these values are corrected, you'll need to find the lower X,Y values:
var lowX = (pt1.X < pt2.X? pt1.X: pt2.X);
var lowY = (pt1.Y < pt2.Y? pt1.Y: pt2.Y);
Then calculate the view by adding the width/2 and height/2 values to the
lowX and lowY values:
GotoView(lowX + mcsW/2, lowY + mcsH/2, scale, true, false);
I have set the Severity to minor, but for myself this was a major issue
and I resolved it in my file.
I have not ran across it, but there may be other areas where drag
direction is assumed and could sometimes be inaccurate.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/518>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
