[mapguide-trac] #519: Mgserver.exe chrashes when ", " is used as decimal separator in locale
MapGuide Open Source trac_mapguide at osgeo.org
Wed Mar 26 05:08:37 EDT 2008
#519: Mgserver.exe chrashes when "," is used as decimal separator in locale
   Reporter:  trondat  |       Owner:
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:
  Component:  Server   |     Version:  2.0.0
   Severity:  major    |    Keywords:
External_id:           |
 The mgserver.exe crashes when there is a locale setting using "," as
 decimal separator on a windows server. This is used in Norwegian locale.
 To reproduce this change the locale to Norwegian ( verify that the decimal
 separator is ",") and set this as the default user setting.
 run the mgserver.exe interactively ( mgserver.exe run) . It produces the
 following output :
 Running the server interactively as an application instead of as a
 service.
 (3032) Failed to retrieve message for "MgInvalidArgumentException".
         [1] = "const string&"
 Failed to retrieve message for "MgInvalidStringConversion".
 Exception occurred in method MgUtil.WideCharToMultiByte at line 297 in
 file
 d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\common\foundation\System/Util.cpp
 (3032) Failed to retrieve message for "MgConnectionNotOpenException".
 Exception occurred in method MgSiteConnection.GetCurrentUserInfo at line
 382 in file
 d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\common\mapguidecommon\System/UserInformation.cpp
 This application has requested the Runtime to terminate it in an unusual
 way.
 Please contact the application's support team for more information.''
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/519>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
