[mapguide-trac] #514: Mapguide Daemon Path Issues On Linux?
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 27 13:09:23 EDT 2008
 Reporter:  Rothgar  |         Owner:  ronnielouie
     Type:  defect   |        Status:  new
 Priority:  high     |     Milestone:
Component:  Server   |       Version:  2.0.0
 Severity:  major    |    Resolution:
 Keywords:           |   External_id:
Comment (by ronnielouie):
 !MapGuide Server should be trying to load serverconfig.ini from
 /home/mapguide/server/bin which you say does exist.  Can you check if
 there is a permissions problem preventing access?  Maybe you could check
 to contents of the file.  The values should be similar to the values from
 the one from svn, except for the paths should reflect the actual paths.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/514#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
