[mapguide-trac] #514: Mapguide Daemon Path Issues On Linux?
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 27 17:54:59 EDT 2008
 Reporter:  Rothgar  |         Owner:  ronnielouie
     Type:  defect   |        Status:  new
 Priority:  high     |     Milestone:
Component:  Server   |       Version:  2.0.0
 Severity:  major    |    Resolution:
 Keywords:           |   External_id:
Comment (by Rothgar):
 Hi Ronnie,
 The permissions are correct, the problem is the "mgserver.sh" file which
 references the same configuration file? Works fine it just runs in the
 foreground.
 The "mgserverd.sh" for some reason maybe the binary has the wrong paths or
 something and is not referencing the file properly when in daemon mode?
 because it says it can't find the file?
 I ran a diff between the "mgserver.sh" and "mgserverd.sh" and the only
 difference is the switch?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/514#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
