[mapguide-trac] #477: Apache mapguide.conf for Linux Problems
MapGuide Open Source trac_mapguide at osgeo.org
Fri May 2 15:30:53 EDT 2008
 Reporter:  amorsell   |         Owner:  ronnielouie
     Type:  defect     |        Status:  new
 Priority:  medium     |     Milestone:  2.1
Component:  Map Agent  |       Version:  2.0.0
 Severity:  major      |    Resolution:
 Keywords:             |   External_id:
Comment (by ronnielouie):
 Hi Zac, thanks for the patch.  You've got the right diagnosis, but
 unfortunately the wrong solution.
 Your patch uncomments the two lines for the Apache mapagent module in
 build_apt.sh.  The usual steps for building on Linux, as described at
 http://wiki.osgeo.org/wiki/Building_MapGuide_quick_starts_guides, involve
 performing build_apt.sh first and then building !MapGuide.
 When build_apt.sh is run, !MapGuide has not been built yet, so the
 mod_mgmapagent.so does not yet exist.  That is why it is uncommented here.
 When building !MapGuide, particularly the 'make install' of the !WebTier
 is supposed to edit the mapguide.conf file to remove the comment
 character.  For some reason, the modifying of mapguide.conf was removed by
 http://trac.osgeo.org/mapguide/changeset/2732.  I will need to look into
 why this was removed.  Otherwise, the correct solution would be to revert
 changeset 2732.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/477#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
