[mapguide-trac] #318: Stream IO exception : "TCP/IP protocol is mismatched between the Server and Web Extensions"
MapGuide Open Source trac_mapguide at osgeo.org
Mon May 5 03:11:01 EDT 2008
Web Extensions"
 Reporter:  fvanderbiest      |         Owner:
     Type:  defect            |        Status:  new
 Priority:  medium            |     Milestone:
Component:  General           |       Version:  2.0.0
 Severity:  major             |    Resolution:
 Keywords:  exception TCP/IP  |   External_id:
Comment (by zspitzer):
 I am seeing this as well on RH 4 ES, compiled from the 2.0 tarball
 (2694028192) A stream IO exception occurred.
 The TCP/IP protocol is mismatched between the Server and Web Extensions.
 Please install the same version of Server and Web Extensions.
 Exception occurred in method MgStreamParser.ParseStreamHeader at line 91
 in file System/StreamParser.cpp
 (2694028192) The connection is not open.
 Exception occurred in method MgSiteConnection.GetCurrentUserInfo at line
 382 in file System/UserInformation.cpp
 terminate called after throwing an instance of
 'MgConnectionNotOpenException*'
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/318#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
