[mapguide-trac] #588: Maestro: Layer Editor visual enhancements
MapGuide Open Source trac_mapguide at osgeo.org
Fri May 30 17:23:49 EDT 2008
   Reporter:  jbirch       |       Owner:  ksgeograf
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 - Currently, the layer editor uses fixed heights for its dialogs.  This
 means that if you add more than three rules to a style, you can not see
 the lower ones.
 - It is difficult to locate specific scale ranges, and I found the
 interface a bit non-intuitive.  I clicked on "Add Scale Range" and
 apparently nothing happened (it had, but I couldn't see it because it was
 below the fold).  I wonder if this would work better as a scale tree on
 the left and tabbed style definitions on the right?
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/588>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
