[mapguide-trac] #588: Maestro: Layer Editor visual enhancements
MapGuide Open Source trac_mapguide at osgeo.org
Fri May 30 17:26:23 EDT 2008
 Reporter:  jbirch       |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  new
 Priority:  low          |     Milestone:
Component:  Maestro      |       Version:
 Severity:  trivial      |    Resolution:
 Keywords:               |   External_id:
Old description:
> - Currently, the layer editor uses fixed heights for its dialogs.  This
> means that if you add more than three rules to a style, you can not see
> the lower ones.
> - It is difficult to locate specific scale ranges, and I found the
> interface a bit non-intuitive.  I clicked on "Add Scale Range" and
> apparently nothing happened (it had, but I couldn't see it because it was
> below the fold).  I wonder if this would work better as a scale tree on
> the left and tabbed style definitions on the right?
New description:
 the lower ones.
 - I believe that it would be more intuitive to have the physical name of
 the column first, and the display name second in the properties dialog.
Comment (by jbirch):
 Added comment about properties dialog
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/588#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
