[mapguide-trac] #733: Feature Service GetWfsFeature fails when a filter is specified
MapGuide Open Source trac_mapguide at osgeo.org
Fri Oct 24 15:08:55 EDT 2008
   Reporter:  chrisclaydon  |       Owner:  chrisclaydon
       Type:  defect        |      Status:  new
   Priority:  high          |   Milestone:  2.1
  Component:  General       |     Version:  2.0.1
   Severity:  trivial       |    Keywords:
External_id:  1145710       |
 1) Install the Sheboygan sample data
 2) Using the web tier test pages, select the Wfs service and !GetFeature
 command.
 3) Leave the default settings as-is, and set the BBOX field to be:
 -87.714582,43.764863,-87.736429,43.772951
 4) Click submit
 This is a valid BBOX filter, but the request will fail with the error: Out
 of range. invalid string position
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/733>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
