[mapguide-trac] #732: Advanced placement problems
MapGuide Open Source trac_mapguide at osgeo.org
Mon Oct 27 16:37:40 EDT 2008
 Reporter:  zspitzer           |         Owner:
     Type:  defect             |        Status:  new
 Priority:  low                |     Milestone:
Component:  Rendering Service  |       Version:  2.0.2
 Severity:  major              |    Resolution:
 Keywords:                     |   External_id:
Comment (by waltweltonlair):
 The stylization code ignores the !ScaleLimit parameter, and effectively
 always uses a limit of 0.5.  If a path label is too long for the current
 feature, it scales it by up to a factor of 0.5 to see if it will fit.
 This happens in RS_FontEngine::!LayoutPathText - see the font_scale
 variable about 30 lines into the method.
 Updating the code to honor the !ScaleLimit setting would not be too much
 work (1/2 day at most, is my estimate).
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/732#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
