[mapguide-trac] #560: Consider adding a repository validator
MapGuide Open Source trac_mapguide at osgeo.org
Mon Oct 27 06:28:53 EDT 2008
 Reporter:  ksgeograf    |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  assigned
 Priority:  medium       |     Milestone:
Component:  Maestro      |       Version:
 Severity:  major        |    Resolution:
 Keywords:               |   External_id:
Comment (by ksgeograf):
 This is the next feature I will work on in Maestro (Repo validator).
 This is a potentially endless point, so I will try to keep a list of known
 problems here. Feel free to add any detail that you wan't Maestro to
 detect as either a warning or error.
  *  FeatureSource:
     *  Perform the "Test Connection"
     *  Perform a "Describe Schema"
     *  Perform a "Get Identitie Columns"
     *  Perform a random select.
   *  Layer
     *  Detect missing featuresource, class, geometry or columns.
     *  Detect no scale ranges (warning)
     *  Detect no items visible in a scale range.
     *  Detect scale ranges with gaps eg. [0-10[ [11-20[ (warning)
     *  Try sample rendering, re-test without filter, labels, links or
 tooltips, to detect errors in these.
     *  Try sample rendering with default font and symbols.
   *  Map
     *  Detect that all layers exist, and their permissions are equvalent
 to the map.
     *  Detect that spatial contexts for layers are within the maps.
     *  Warn if coordinate systems are not the same (performance penalty).
     *  Warn (error?) if raster layer is not in the same coordinate system.
     *  Perhaps check for visibility logic, ea. order should be: rasters,
 polygon layers, lines, then points.
   *  Layout
     *  Check that the map exists.
     *  Check that the startup is within the map bounds.
   *  Fusion
     *  Same as layout.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/560#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
