[mapguide-trac] #1121: MrSID images fail to display in MapGuide 2.1
MapGuide Open Source trac_mapguide at osgeo.org
Mon Dec 7 07:02:59 EST 2009
 Reporter:  martinmorrison     |         Owner:
     Type:  defect             |        Status:  new
 Priority:  high               |     Milestone:  2.1
Component:  Rendering Service  |       Version:  2.1.0
 Severity:  blocker            |    Resolution:
 Keywords:                     |   External_id:
Comment (by djonio):
 Additional XML data from functioning MGOS 2.0.2 server and XML from
 failing MGOS 2.1 server. Same MrSID file. MrSID download instructions sent
 to Jason Burch.
 #####                       MAPGUIDE ERROR LOG:
 <2009-12-05T16:37:03> 5816
  Success: Server stopped.
 <2009-12-05T16:42:14> 852
  Success: Server started.
 <2009-12-05T17:13:23> 5652 Ajax Viewer 10.14.X.XX Administrator
  Error: Failed to stylize layer: Aerial2008SP
         The coordinate system initialization failed.
         Could not initialize the geodetic transformation.
  StackTrace:
   - MgMappingUtil.StylizeLayers() line 776 file
 c:\osgeo\mapguide_21\mgdev\server\src\services\mapping\MappingUtil.cpp
 #####                  MAPGUIDE server runtime w/CPL_DEBUG:
 C:\Program Files\OSGeo\MapGuide\Server\bin>mgserver run
 Running the server interactively as an application instead of as a
 service.
 (852) Server starting...
 (852) Mentor Coordinate System Library
 (852) Server started.
 GDAL: Auto register C:\Program
 Files\OSGeo\MapGuide\Server\bin\gdalplugins\gdal_ECW_JP2ECW.dll using
 GDALRegister_ECW_JP2ECW.
 Files\OSGeo\MapGuide\Server\bin\gdalplugins\gdal_MrSID.dll using
 GDALRegister_MrSID.
 GDALRegister_MrSID.
 #####               XML from MGOS 2.0.2 - FdoSpatialContextList
 <?xml version="1.0"?>
 <FdoSpatialContextList xmlns:xsi="http://www.w3.org/2001/XMLSchema-
 instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"
 xsi:noNamespaceSchemaLocation="FdoSpatialContextList-1.0.0.xsd">
   <ProviderName>OSGeo.Gdal.3.3</ProviderName>
   <SpatialContext IsActive="true">
     <Name>NAD83(HARN) / Florida East (ftUS)</Name>
     <Description>This coordinate system has been overridden.</Description>
     <CoordinateSystemName>PROJCS["FL83-
 EF",GEOGCS["LL83",DATUM["NAD83",SPHEROID["GRS1980",6378137.000,298.25722210]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["false_easting",656166.667],PARAMETER["false_northing",0.000],PARAMETER["scale_factor",0.999941176471],PARAMETER["central_meridian",-81.00000000000000],PARAMETER["latitude_of_origin",24.33333333333333],UNIT["Foot_US",0.30480060960122]]</CoordinateSystemName>
     <CoordinateSystemWkt>PROJCS["FL83-
 EF",GEOGCS["LL83",DATUM["NAD83",SPHEROID["GRS1980",6378137.000,298.25722210]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["false_easting",656166.667],PARAMETER["false_northing",0.000],PARAMETER["scale_factor",0.999941176471],PARAMETER["central_meridian",-81.00000000000000],PARAMETER["latitude_of_origin",24.33333333333333],UNIT["Foot_US",0.30480060960122]]</CoordinateSystemWkt>
     <ExtentType>Dynamic</ExtentType>
     <Extent>
       <LowerLeftCoordinate>
         <X>877070.59535700001</X>
         <Y>524581.66131</Y>
       </LowerLeftCoordinate>
       <UpperRightCoordinate>
         <X>902690.59535700001</X>
         <Y>539301.66131</Y>
       </UpperRightCoordinate>
     </Extent>
     <XYTolerance>0</XYTolerance>
     <ZTolerance>0</ZTolerance>
   </SpatialContext>
 </FdoSpatialContextList>
 #####               XML from MGOS 2.0.2 - FeatureSource
 <?xml version="1.0" encoding="utf-8"?>
 <FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
 xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
   <Provider>OSGeo.Gdal</Provider>
   <Parameter>
     <Name>DefaultRasterFileLocation</Name>
     <Value> C:\OSGeoData\MIA\Aerial200SP </Value>
   </Parameter>
   <SupplementalSpatialContextInfo>
     <CoordinateSystem>PROJCS["FL83-
 EF",GEOGCS["LL83",DATUM["NAD83",SPHEROID["GRS1980",6378137.000,298.25722210]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["false_easting",656166.667],PARAMETER["false_northing",0.000],PARAMETER["scale_factor",0.999941176471],PARAMETER["central_meridian",-81.00000000000000],PARAMETER["latitude_of_origin",24.33333333333333],UNIT["Foot_US",0.30480060960122]]</CoordinateSystem>
   </SupplementalSpatialContextInfo>
 </FeatureSource>
 #####          XML from MGOS 2.1 - FdoSpatialContextList
   <ProviderName>OSGeo.Gdal.3.4</ProviderName>
     <Name>Default</Name>
     <Description>System generated default FDO Spatial
 Context</Description>
     <CoordinateSystemName>Default</CoordinateSystemName>
     <CoordinateSystemWkt>LOCAL_CS["*XY-
 MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
 1],AXIS["X",EAST],AXIS["Y",NORTH]]</CoordinateSystemWkt>
     <ExtentType>Static</ExtentType>
     <Extent>
         <X>-10000000</X>
         <Y>-10000000</Y>
         <X>10000000</X>
         <Y>10000000</Y>
     </Extent>
     <XYTolerance>0.001</XYTolerance>
     <ZTolerance>0.001</ZTolerance>
   </SpatialContext>
 #####               XML from MGOS 2.1 - FeatureSource
   <Parameter>
     <Value>C:\OSGeoData\MIA\Aerial200SP</Value>
   </Parameter>
 </FeatureSource>
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1121#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
