[mapguide-trac] #1153: Update the default path to the Mentor dictionaries to use on the Linux, when the MENTOR_DICTIONARY_PATH is not defined in the system
MapGuide Open Source trac_mapguide at osgeo.org
Tue Dec 8 04:33:39 EST 2009
 Reporter:  hubu     |         Owner:  hubu
     Type:  defect   |        Status:  new
 Priority:  high     |     Milestone:  2.2
Component:  Fusion   |       Version:  2.1.0
 Severity:  blocker  |    Resolution:
 Keywords:           |   External_id:  1276545
Comment (by hubu):
 I have updated the patch. In this patch, I remove the MGE path from the
 source code and define the opensource path in the CoordSysEnvVariable.h
 for Opensource using.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1153#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
