[mapguide-trac] #859: Maestro: MgCooker fails to run after unchecking Base Layer Group then selecting individual zoom levels
MapGuide Open Source trac_mapguide at osgeo.org
Sat Feb 21 20:54:24 EST 2009
 Reporter:  jbirch   |         Owner:  ksgeograf
     Type:  defect   |        Status:  new
 Priority:  medium   |     Milestone:
Component:  Maestro  |       Version:
 Severity:  minor    |    Resolution:
 Keywords:           |   External_id:
Old description:
> When trying to set up an MgCooker task, I initially wanted to try with a
> single zoom level.  In order to do this, I unchecked the "Base Layer
> Group" level to unselect all, and then checked the individual zoom level.
> When I click on Build Tiles Now, the dialog goes away.
> I believe that this is happening because when I uncheck the "Base Layer
> Group" the Library level is also unchecked, but when I re-check a single
> layer the top level is not re-checked.
New description:
 When trying to set up an !MgCooker task, I initially wanted to try with a
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/859#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
