[mapguide-trac] #887: mod_mgmapagent.so (built from svn) will not load in Apache
MapGuide Open Source trac_mapguide at osgeo.org
Wed Mar 11 04:11:41 EDT 2009
   Reporter:  jng        |       Owner:
       Type:  defect     |      Status:  new
   Priority:  high       |   Milestone:  2.1
  Component:  Map Agent  |     Version:
   Severity:  blocker    |    Keywords:
External_id:             |
 When attempting to run Apache using the web extensions built from svn
 trunk, it will error out with the following message:
 httpd.exe: Syntax error on line 195 of C:/Program Files/OSGeo/MapGuide
 Web/Apache2/conf/httpd.conf: Cannot load C:/Program Files/OSGeo/MapGuide
 Web/Apache2/modules/mod_mgmapagent.so into server: This application has
 failed to start because the application configuration is incorrect.
 Reinstalling this application may fix this problem.
 The message sounds remotely familiar to something that the Visual C++ CRT
 would throw out. I did a depends.exe on mod_mgmapagent.so and I have found
 references to Visual C++ 2005 CRT dlls (MSVCP80.dll and MSVCR80.dll). The
 code-base has moved to VS 2008 so maybe these references should not be
 there?
 I am blocker-izing this issue because this error prevents us from having a
 functional Apache configuration for the community-based installer.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/887>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
