[mapguide-trac] #887: mod_mgmapagent.so (built from svn) will not load in Apache
MapGuide Open Source trac_mapguide at osgeo.org
Wed Mar 11 18:21:59 EDT 2009
 Reporter:  jng        |         Owner:
     Type:  defect     |        Status:  new
 Priority:  high       |     Milestone:  2.1
Component:  Map Agent  |       Version:
 Severity:  blocker    |    Resolution:
 Keywords:             |   External_id:
Comment (by tomfukushima):
 Hi Jackie,
 If you build the mod_mgmapagent.so using VS 2008 it will reference the
 correct DLLs.  The project to build it is the ApacheAgent project in the
 WebTier solution.
 I'm pretty sure of this because the one that I have built only references
 msvcp90.dll and msvcr90.dll.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/887#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
