[mapguide-trac] #520: Out of memory. bad allocation Errors using Tiled Map
MapGuide Open Source trac_mapguide at osgeo.org
Sun Mar 29 22:06:40 EDT 2009
 Reporter:  zspitzer       |         Owner:
     Type:  defect         |        Status:  reopened
 Priority:  medium         |     Milestone:  2.1
Component:  Tile Service   |       Version:  2.1.0
 Severity:  major          |    Resolution:
 Keywords:  out of memory  |   External_id:
Changes (by uvlite):
  * keywords:  => out of memory
 * cc: walt.welton-lair at autodesk.com (added)
  * version:  2.0.2 => 2.1.0
  * milestone:  => 2.1
Comment:
 I also observed this problem on revision 3767.
 That's last Fridays 27 march 2009 trunk checkout!!
 This was a release build using a FDO rev 4507 from the same day ....
 Sheboygan works fine.....
 9 parallel requests from a tiled map are enough to through the server over
 e.g. it stops processing any further requests
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/520#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
