[mapguide-trac] #939: jdk version problems
MapGuide Open Source trac_mapguide at osgeo.org
Mon Mar 30 05:58:29 EDT 2009
   Reporter:  alucas     |       Owner:
       Type:  defect     |      Status:  new
   Priority:  high       |   Milestone:  2.1
  Component:  Installer  |     Version:  2.1.0
   Severity:  minor      |    Keywords:  java installer
External_id:             |
 Hello,
 I found problems installing the unofficial 2.1.0 with java configuration.
 If the user is running jdk 1.6.0_12 (currently the latest version), when
 the installation ends tomcat service will not start.
 From tomcat log:
 [2009-03-27 23:53:56] [174  javajni.c] [error] the specified module could
 not be found.
 [2009-03-27 23:53:56] [986  prunsrv.c] [error] Failed creating java
 [2009-03-27 23:53:56] [1260 prunsrv.c] [error] ServiceStart returned 1
 It seems there is a problem with msvcr71.dll, I found two workarounds:
  1) copy msvcr71.dll into tomcat bin directory.
  2) Downgrade to jdk 1.5.0_xx
 I suppose that the correct way is to include this assembly into the
 installer.
 Thanks.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/939>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
