[mapguide-trac] #979: WebLayout XML must be formatted/indented correctly whereas others (Layer, MapDefinition, Data) do not.
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 6 06:14:34 EDT 2009
   Reporter:  cagray       |       Owner:
       Type:  defect       |      Status:  new
   Priority:  low          |   Milestone:
  Component:  AJAX Viewer  |     Version:  2.1.0
   Severity:  trivial      |    Keywords:
External_id:               |
 When creating new resources from a xml string or file using the Web API
 the formatting (newlines/indenting) of the XML does not matter for Data,
 Layer or MapDefinition resources. However for WebLayout resources it does.
 If incorrectly formatted you get:
 Argument is null. Argument is null
 when you try and view it in the AJAX viewer through a web page (not in
 Maestro which works). If you save this resource in Maestro it fixes it as
 it formats the XML.
 I would have thought that the XML in Mapguide should not rely upon the
 indenting etc?
 I resolved this in my .NET application by running the function on the xml
 string:
 public static String FormatXMLString(string sUnformattedXML)
         XmlDocument xd = new XmlDocument();
         xd.LoadXml(sUnformattedXML);
         StringBuilder sb = new StringBuilder();
         StringWriter sw = new StringWriter(sb);
         XmlTextWriter xtw = null;
         try
                 xtw = new XmlTextWriter(sw);
                 xtw.Formatting = Formatting.Indented;
                 xd.WriteTo(xtw);
         finally {
                 if (xtw != null)
                         xtw.Close();
         return sb.ToString();
 and setting PreserveWhiteSpace = true on the XMLDocument object which
 reads the XML String/File in before encoding it to UTF8 bytes and
 submitting to MapGuide using SetResource.
 NOTE: My xml does not have a BOM so it is not a UTF-8 encoding issue as
 far as I am aware.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/979>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
