[mapguide-trac] #979: WebLayout XML must be formatted/indented correctly whereas others (Layer, MapDefinition, Data) do not.
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 6 06:46:40 EDT 2009
 Reporter:  cagray       |         Owner:
     Type:  defect       |        Status:  new
 Priority:  low          |     Milestone:
Component:  AJAX Viewer  |       Version:  2.1.0
 Severity:  trivial      |    Resolution:
 Keywords:               |   External_id:
Comment (by ksgeograf):
 I have seen that Studio chokes with a similar error, which is why Maestro
 indents the xml.
 I have the impression that Studio uses some of the same !MapGuide dll's
 (!MdfParser?), which could explain why this issue is also present in the
 !MapGuide code.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/979#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
