[mapguide-trac] #982: Installer dosen't create virtual dir mapviewnet
MapGuide Open Source trac_mapguide at osgeo.org
Sun May 10 18:29:06 EDT 2009
 Reporter:  nimcnaan   |         Owner:  jbirch
     Type:  defect     |        Status:  assigned
 Priority:  medium     |     Milestone:  2.1
Component:  Installer  |       Version:  2.1.0
 Severity:  major      |    Resolution:
 Keywords:             |   External_id:
Changes (by jbirch):
  * status:  new => assigned
  * owner:  nimcnaan => jbirch
  * component:  General => Installer
  * severity:  trivial => major
 * cc: jng (added)
Comment:
 I don't believe that that directory is supposed to be mapped as a virtual
 dir / application; it's only supposed to be referenced by the
 mapviewerajax virtual directory, and then only if the .Net viewer is
 selected during installation.  Are you saying that mapviewernet isn't
 properly referenced by the mapviewerajax virtual directory?
 If this is the case, did you select an IIS install, select the .Net
 viewer, and have ASP.Net 2.0 installed before you ran the installer?
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/982#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
