[mapguide-trac] #982: Installer dosen't create virtual dir mapviewnet
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 20 07:18:24 EDT 2009
 Reporter:  nimcnaan   |         Owner:  jbirch
     Type:  defect     |        Status:  assigned
 Priority:  medium     |     Milestone:  2.1
Component:  Installer  |       Version:  2.1.0
 Severity:  major      |    Resolution:
 Keywords:             |   External_id:
Comment (by crispinatime):
 All,
 If this is not set as an application then the Web Tier Tests fail under
 the "Server Admin" where some of the DotNet tests reference this
 application in the test URL.
 This is still not set in the XP-version of installer 0.7
  Crispin
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/982#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
