[mapguide-trac] #1007: Maestro: MgCooker does not use the connection settings provided in the dialog
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 28 02:47:55 EDT 2009
dialog
   Reporter:  ksgeograf  |       Owner:  ksgeograf
       Type:  defect     |      Status:  new
   Priority:  low        |   Milestone:  Maestro-2.0
  Component:  Maestro    |     Version:
   Severity:  trivial    |    Keywords:
External_id:             |
 If you enter different settings in the MgCooker configuration window and
 then click "Build tiles now", it will use the current connection, and thus
 ignore any setting changes.
 If it runs in batch mode, the commandline parameters are used, and it
 works as expected.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1007>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
