[mapguide-trac] #1006: Web Layout not working
MapGuide Open Source trac_mapguide at osgeo.org
Fri May 29 03:43:42 EDT 2009
 Reporter:  JackOfHearts  |         Owner:
     Type:  defect        |        Status:  closed
 Priority:  high          |     Milestone:
Component:  General       |       Version:  2.1.0
 Severity:  major         |    Resolution:  fixed
 Keywords:  web, layout   |   External_id:
Changes (by JackOfHearts):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Thank you. :)
 This partially solved the problem. After I've set all of the mapguide
 virtuals to ASP.NET 2.0, there was another error "Server application
 unavailable". This is familiar error to me and was easily solver with
 executing "aspnet_regiis -i" in windows\Microsoft.net\framework\v2.0.50727
 directory.
 Thank you again for you help. Back to further testing :)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1006#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
