[mapguide-trac] #1113: Maestro: consider supporting TCP connections
MapGuide Open Source trac_mapguide at osgeo.org
Tue Nov 10 17:07:22 EST 2009
 Reporter:  jbirch       |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  new
 Priority:  low          |     Milestone:
Component:  Maestro      |       Version:
 Severity:  trivial      |    Resolution:
 Keywords:               |   External_id:
Comment (by jbirch):
 That really does sound like a lot of work for the benefit.
 The use case that I'm considering is where the web server is not
 configured for authoring, or is on a different server than the mapguide
 service. This would avoid having to configure authoring from a different
 web app or, in the latter case, having to install a web server on the
 mapguide server machine or another interal server.
 Given how much difficulty Haris is having getting GeoREST to talk to
 different MapGuide versions, I don't think this is worth considering until
 some kind of native API versioning is in place, even if it is deemed
 important enough to consider.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1113#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
