[mapguide-trac] #1121: MrSID images fail to display in MapGuide 2.1
MapGuide Open Source trac_mapguide at osgeo.org
Wed Oct 21 09:30:07 EDT 2009
   Reporter:  martinmorrison     |       Owner:
       Type:  defect             |      Status:  new
   Priority:  high               |   Milestone:  2.1
  Component:  Rendering Service  |     Version:  2.1.0
   Severity:  blocker            |    Keywords:
External_id:                     |
 MrSID images fail to display in MapGuide 2.1  I have a 2.02 site up that
 displays the MrSID perfectly.  Using the same install procedure against
 2.1 fails to display an image.
 I have also followed the directions posted by Jason Birch in
 http://www.mail-archive.com/mapguide-users@lists.osgeo.org/msg10886.html
 Specific version details are MG 2.1 on Apache (using the bundled
 install),GDAL 3.4.  The MrSID files are in the same coordinate system as
 the map.
 After loading the MrSID dll'd, if run the server from the command line, I
 get errors that reference the ECW dlls.  If I load the ECW dlls, the
 errors go away but the map still does not display the MrSID files.  The
 map does take an extraordinary amount of time to display though.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1121>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
