[mapguide-trac] #1122: MGOS 2.0.2 or MGOS 2.1 not compatible for using PostGIS 1.4
MapGuide Open Source trac_mapguide at osgeo.org
Wed Oct 21 10:09:31 EDT 2009
   Reporter:  ssddgreg  |       Owner:
       Type:  defect    |      Status:  new
   Priority:  high      |   Milestone:
  Component:  General   |     Version:  2.1.0
   Severity:  blocker   |    Keywords:  postgis
External_id:            |
 I have seached several forums for more than two working days for solution
 to error in Windows environment (32-bit) - reporduced on Windows XP and
 Windows Server 2003
 "Failed to read schema from data source"
 The Operation gave the error message. The remote server returned an error:
 (559) MgConnectionFailedExeception.:Cannot establiosh connection."
 Please note that PosrGRESQL 8.4 is running well, as well as PostGIS
 module. All required DLL files from PostGRESQL 8.4 were copied to the
 Program Files\OSGeo\MapGuide\Server\Fdo folder and restarted the MapGuide
 Server service.
 However, Data Connection was tested successfull without any errors, just
 when trying to select the PostGIS data connection, it fails.
 The same occurs with the Autodesk MapGuide Studio 2010 when accessing the
 MGOS 2.1 beta.
 It is an essential step in our solution for our customer and we need to
 know, if this works on Windows platforms well. For now, we did not have
 any success and would need good support in this. Already reported to
 Autodesk for the MGE Studio 2010.
 pg_hba.conf
 host    all         all         127.0.0.1/32          md5
 host    all         all         0.0.0.0/0             trust
 pg_ident.conf
 empty
 postgresql.conf
 listen_addresses = '*'
 No firewalls enabled, no antivirus installed.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1122>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
