[mapguide-trac] #1332: Tile Cache should only be cleared if the saved Map Definition resource has changes in base layer settings
MapGuide Open Source trac_mapguide at osgeo.org
Tue Apr 27 05:01:12 EDT 2010
 Reporter:  jng           |         Owner:
     Type:  defect        |        Status:  new
 Priority:  high          |     Milestone:
Component:  Tile Service  |       Version:
 Severity:  critical      |    Resolution:
 Keywords:                |   External_id:
Comment (by zspitzer):
 i think adding a dynamic layer to a non base map group can change the map
 bounds,
 which alas makes sense to clear the map
 this is really horrible but hard to solve problem, best discussed on
 internals i reckon
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1332#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
