[mapguide-trac] #1561: Flyout menus do not expand in vertical space if one or more items have label text spanning more than one line
MapGuide Open Source trac_mapguide at osgeo.org
Wed Dec 8 08:59:18 EST 2010
   Reporter:  jng          |       Owner:
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:
  Component:  AJAX Viewer  |     Version:  2.1.0
   Severity:  trivial      |    Keywords:
External_id:               |
 Create a web layout with a toolbar flyout menu containing at least one
 command whose label text spans more than one line.
 Put several other commands under this command. When you look at this
 flyout menu, the menu will most likely cut the last command item in half
 because it does not expand in vertical space that was taken up by the
 command with the really long label text.
 See attached screenshot
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1561>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
