[mapguide-trac] #1562: Web Layout Editor loose ends
MapGuide Open Source trac_mapguide at osgeo.org
Wed Dec 8 09:09:29 EST 2010
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-3.0
  Component:  Maestro  |     Version:  2.1.0
   Severity:  trivial  |    Keywords:
External_id:           |
 The Web Layout editor in Maestro 3.0 has some loose ends that require
 fixing up:
  * Adding new commands will correctly add the corresponding entries in the
 menus toolbar, but the labels are blank.
  * The button in the Invoke URL command editor that should launch a layer
 selector does not work.
  * Icons should be shown beside each command, or at least show icons for
 the custom commands (Invoke URL, Search, Invoke Script)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1562>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
