[mapguide-trac] #1222: Maestro: allow setting Map's coordinate system to that of one of the layers
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jan 4 16:54:24 EST 2010
 Reporter:  jbirch       |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  closed
 Priority:  low          |     Milestone:
Component:  Maestro      |       Version:
 Severity:  trivial      |    Resolution:  fixed
 Keywords:               |   External_id:
Changes (by ksgeograf):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Fixed with r4478.
 I have fixed this by adding to extra checks.
 When clicking the "Set extent to layers extent" there is now a check to
 see if the maps coordinate system is the same, and offers to set the
 coordinate system to match.
 When browsing for a coordinate system, it will check to see if the current
 selected layer (or select the first layer in the list) has the same
 coordinate system as the map. If not, it will offer to use that coordinate
 system instead of showing the coordinate system browser.
 I can see that there is a request for extra functions, such as guessing
 the coordinate system, based on the number of coordinate systems in the
 map. I'm closing it now, because I think it offers the basic functionality
 requested, without requiring a new user interface component. If you feel
 that the solution is not sufficient, feel free to re-open.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1222#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
