[mapguide-trac] #1236: "Sticky" tooltips
MapGuide Open Source trac_mapguide at osgeo.org
Mon Oct 11 19:28:21 EDT 2010
   Reporter:  jng          |       Owner:  liuar
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  AJAX Viewer  |     Version:
   Severity:  major        |    Keywords:
External_id:               |
Comment(by jng):
 Okay, I've found the problem. The Districts layer of the Sheboygan dataset
 has the wrong label expression. It is using the expression:
 concat('District ', Autogenerated_SDF_ID)
 The Autogenerated_SDF_ID does not line up with the label, hence the
 disparate tooltips.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1236#comment:8>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
