[mapguide-trac] #1460: Maestro sometimes crashes when making package
MapGuide Open Source trac_mapguide at osgeo.org
Tue Oct 12 15:06:59 EDT 2010
   Reporter:  andrewd  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Maestro  |     Version:  2.1.0
   Severity:  minor    |    Keywords:
External_id:           |
 I've had this happen a few times before, with other version of Maestro,
 but this time decided that there must really be a problem - so I'm posting
 my crash details....I get these crashes on occasion when trying to make a
 package of my entire server. It will work for a while (maybe 25%) and then
 crash. Usually, if I just try it again later, it works fine. This is using
 MGOS 2.0.2 and Maestro 2.1.4 (and earlier).
 See the end of this message for details on invoking
 just-in-time (JIT) debugging instead of this dialog box.
 ************** Exception Text **************
 System.NotSupportedException: WebClient does not support concurrent I/O
 operations.
    at
 OSGeo.MapGuide.MaestroAPI.PackageBuilder.PackageProgress.backgroundWorker_RunWorkerCompleted(Object
 sender, RunWorkerCompletedEventArgs e)
    at
 System.ComponentModel.BackgroundWorker.OnRunWorkerCompleted(RunWorkerCompletedEventArgs
 e)
    at
 System.ComponentModel.BackgroundWorker.AsyncOperationCompleted(Object arg)
 ************** Loaded Assemblies **************
 mscorlib
     Assembly Version: 2.0.0.0
     Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900)
     CodeBase:
 file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
 Maestro
     Assembly Version: 2.1.4.5245
     Win32 Version: 2.1.4.5245
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/Maestro.exe
 OSGeo.MapGuide.Maestro.LoginForm
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.Maestro.LoginForm.DLL
 System.Windows.Forms
     Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
     CodeBase:
 file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
 System
     CodeBase:
 file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
 System.Drawing
     CodeBase:
 file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
 System.Xml
     CodeBase:
 file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
 System.Configuration
     CodeBase:
 file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
 u7onbioq
     CodeBase:
 OSGeo.MapGuide.Maestro.MaestroEditorInterface
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.Maestro.MaestroEditorInterface.DLL
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.MaestroAPI.DLL
 OSGeo.MapGuide.Maestro.ResourceBrowser
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.Maestro.ResourceBrowser.DLL
 OSGeo.MapGuide.Maestro.ResourceValidators
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.Maestro.ResourceValidators.DLL
 System.Data
     CodeBase:
 file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
 System.Web
     Win32 Version: 2.0.50727.4955 (win7RTMGDR.050727-4900)
     CodeBase:
 file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
 Microsoft.JScript
     Assembly Version: 8.0.0.0
     Win32 Version: 8.0.50727.4927
     CodeBase:
 file:///C:/Windows/assembly/GAC_MSIL/Microsoft.JScript/8.0.0.0__b03f5f7f11d50a3a/Microsoft.JScript.dll
 _vos6zfw
     CodeBase:
 0kphltg1
     CodeBase:
 OSGeo.MapGuide.Maestro.ResourceEditors
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.Maestro.ResourceEditors.DLL
 OSGeo.MapGuide.Maestro.FusionEditor
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.Maestro.FusionEditor.DLL
 lfbr0bch
     CodeBase:
     CodeBase:
 file:///C:/Program%20Files%20(x86)/OSGeo/MapGuideMaestro/OSGeo.MapGuide.MaestroAPI.PackageBuilder.DLL
 dqocx1po
     CodeBase:
 2jw2_yol
     CodeBase:
 sqy07bcd
     CodeBase:
 ms1jf6ut
     CodeBase:
 ************** JIT Debugging **************
 To enable just-in-time (JIT) debugging, the .config file for this
 application or computer (machine.config) must have the
 jitDebugging value set in the system.windows.forms section.
 The application must also be compiled with debugging
 enabled.
 For example:
 <configuration>
     <system.windows.forms jitDebugging="true" />
 </configuration>
 When JIT debugging is enabled, any unhandled exception
 will be sent to the JIT debugger registered on the computer
 rather than be handled by this dialog box.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1460>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
