[mapguide-trac] #1479: GetMapImage in WebTier Api returns error when requesting JPG
MapGuide Open Source trac_mapguide at osgeo.org
Wed Oct 20 09:19:18 EDT 2010
   Reporter:  gBecker  |       Owner:
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Web API  |     Version:  2.2.0
   Severity:  trivial  |    Keywords:
External_id:           |
 Making a GETMAPIMAGE-Request with Format "JPG" results in the following
 message:
 Problem:
 The application encountered a problem and could not finish the operation
 you just requested properly.
 Solution:
 If it's the first time you met this problem, try again or restart the
 application / session; otherwise, describe the steps to reproduce this
 problem to the server administrator for suggestions.
 This works with v2.1 but not with v2.2
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1479>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
