[mapguide-trac] #1478: Theming of ODBC database layer errors
MapGuide Open Source trac_mapguide at osgeo.org
Tue Oct 26 08:19:01 EDT 2010
   Reporter:  andrewd  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:  Maestro-3.0
  Component:  Maestro  |     Version:
   Severity:  major    |    Keywords:
External_id:           |
Comment(by andrewd):
 MS Access - right. The columns in question are:
 data type = "number", field size = "single"
 data type = "text", field size = "255"
 The singles never work. I always get that same error. Interestingly, just
 now, when I was trying to get a refresher on the problem, I tried one of
 the 255 char fields first, and it worked. Now, that field had no data in
 it, so I got "no non-null values" message - fair enough. It could be that
 Maestro just freezes after a while while in the Theme Creator, and because
 my 255 text fields are at the end, it just happens to freeze when I get to
 them.
 I can't make it freeze by doing the exact same thing each time, but I
 ''can'' make it freeze everytime. It seems as if I just go into the Theme
 Creator and keep flipping between different fields (there are about 15 in
 my table), it will eventually freeze up - usually on a text field (if not
 always).
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1478#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
