[mapguide-trac] #1666: Maestro 3 - XML Mode Toolbar Validation Fails
MapGuide Open Source trac_mapguide at osgeo.org
Fri Apr 15 10:22:18 EDT 2011
   Reporter:  crispinatime  |       Owner:  jng
       Type:  defect        |      Status:  new
   Priority:  low           |   Milestone:  Maestro-3.0
  Component:  Maestro       |     Version:
   Severity:  minor         |    Keywords:
External_id:                |
Comment(by crispinatime):
 The path in the warning message is because the path is simply missing
 "\Schemas\" from between "\Release\" and the "...xsd".
 I assumed it would be the same fn call as the Validate on the main toolbar
 so was surprised to see the warning.
 It is minor, just gives false sense of insecurity about manual XML editing
 at the moment.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1666#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
