[mapguide-trac] #1666: Maestro 3 - XML Mode Toolbar Validation Fails
MapGuide Open Source trac_mapguide at osgeo.org
Fri Apr 15 10:31:12 EDT 2011
   Reporter:  crispinatime  |       Owner:  jng
       Type:  defect        |      Status:  new
   Priority:  low           |   Milestone:  Maestro-3.0
  Component:  Maestro       |     Version:
   Severity:  minor         |    Keywords:
External_id:                |
Comment(by jng):
 Generally speaking, when you specify a relative path to something, it is
 assumed to be relative to the working directory of the application, which
 is the directory with Maestro.exe most of the time.
 I'm guessing because the xsi:noNamespaceSchemaLocation is not an absolute
 path, this is where it tries to find the xsd. But I don't know how to tell
 the xml validator to look in our configured XML schema path instead
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1666#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
