[mapguide-trac] #1580: FDO error happened when multi-selecting ODBC data in Flexible Web Layout
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jan 10 01:47:57 EST 2011
   Reporter:  ChristineBao  |       Owner:  Christine Bao
       Type:  defect        |      Status:  new
   Priority:  high          |   Milestone:
  Component:  Server        |     Version:  2.1.0
   Severity:  major         |    Keywords:
External_id:  1376737       |
 Report from Autodesk QA:[[BR]]
 Steps:[[BR]]
 1. Connect to sample Parcels.mdb.[[BR]]
 2. New one FWL against the data.[[BR]]
 3. View in the Browsers.[[BR]]
 4. Select Radius
 Results:[[BR]]
 One warning popped-up. [[BR]]
 An exception occurred in FDO component.
 Expected results:[[BR]]
 No error and objects can be selected correctly/[[BR]]
 Workaround: Y for Fusion, N for Basic.
 Fusion: Select object one by one.
 Regression: Y
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1580>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
