[mapguide-trac] #1580: FDO error happened when multi-selecting ODBC data in Flexible Web Layout
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jan 10 01:52:21 EST 2011
   Reporter:  ChristineBao  |       Owner:  Christine Bao
       Type:  defect        |      Status:  new
   Priority:  high          |   Milestone:
  Component:  Server        |     Version:  2.1.0
   Severity:  major         |    Keywords:
External_id:  1376737       |
Comment(by ChristineBao):
 This defect is caused by selection set generate filter. The ODBC
 provider's primary key is "Primary Key" with a blank character inside,
 which cause the generated filter string something like "(Primary
 key=14769) OR (Primary key=16014)". [[BR]]
 Fixing the defect by adding "\"" to property name if it contains blank
 character.
 Attach a patch for fixing.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1580#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
