[mapguide-trac] #1588: Update license checking code
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jan 21 13:06:25 EST 2011
   Reporter:  brucedechant  |       Owner:
       Type:  enhancement   |      Status:  new
   Priority:  low           |   Milestone:  2.3
  Component:  General       |     Version:  2.2.0
   Severity:  trivial       |    Keywords:
External_id:                |
 Change the exisitng license checking code to allow the CheckLicense() API
 to be overriden for any operation or to use the parent method.
 Note: The LicenseManager method called by the CheckLicense() API doesn't
 actually do anything. If you want to implement your own licensing you will
 need to add your own license checking code there.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1588>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
